Clunk in front end
Hi guys I have a 2002 Monte Carlo LS Sport, I have a clucking in the front of the car that i can feel through the wheel, I checked the struts, tie rods ,ball joints and cant seem to find anything ? Does anyone else have this problem ? It has been getting wore within the last year, It has 55000 miles on it, It will do it all the time, PLZ help thanks
ISS=Intermediate Steering Shaft.
The short term patch is a re-lube. Replacement is the long term provided GM actually came up with a better replacement part.
I had mine replaced and I am not convinced it fixed the long term problem.
It should still be safe, just an annoyance. I am sure the long term problems associated with the noise/feel could eventually cause failure.
I would check with your dealer and ask them if there is a re-call open on your car for this ISS problem. Rough cost if I remember was around $150-$200 for the re-lube patch.
Does anyone remember the TSB # on this one???
