car misses when idleing...
Old Jan 6, 2006 | 01:14 PM
miklin83's Avatar
Default car misses when idleing...
Hope this is the right place. This is my 1st post and it's for my friend's car. She has a 1998 Monte Carlo 3.1 V6. She put about $2000 into it, has taken it to PepBoys and 3-4 local garages. Wires and plugs replaced and new fuel injector. Her problem is the car misses when idleing. When she had fuel injector replaced it didn't miss for about 1 week then started again. Is the piston bad or cracked??? Any help would be appreciated. Thanks! ~Linda
Old Jan 10, 2006 | 07:13 PM
chevy_jj's Avatar
Default RE: car misses when idleing...
start switching plug wires around cylinders. switch them so they are still at the corresponding cylinder. take the one that the injector was replaced and switch it with a good wire. if the miss jumps cylinders its the wire. if it doesnt switch then try swaping spark plugs. if that doesnt change it then you are looking at a injector again or a valvetrain condition.
Old Apr 30, 2006 | 03:05 PM
speeddemon01's Avatar
check the intake for leaks oil and vacuum
00SSsupercharged
Apr 14, 2015 09:21 AM
green98
Jan 24, 2015 04:37 PM
Meadsy69
Oct 8, 2013 11:25 AM
Enilced
18
Aug 5, 2011 06:19 PM
06LTMonte
Aug 24, 2010 02:49 AM
