Clunk in front end
Old Apr 30, 2006 | 10:58 AM
yzf125's Avatar
Default Clunk in front end
Hi guys I have a 2002 Monte Carlo LS Sport, I have a clucking in the front of the car that i can feel through the wheel, I checked the struts, tie rods ,ball joints and cant seem to find anything ? Does anyone else have this problem ? It has been getting wore within the last year, It has 55000 miles on it, It will do it all the time, PLZ help thanks
Old Apr 30, 2006 | 11:03 AM
montejass's Avatar
Default RE: Clunk in front end
ISS=Intermediate Steering Shaft.
The short term patch is a re-lube. Replacement is the long term provided GM actually came up with a better replacement part.
I had mine replaced and I am not convinced it fixed the long term problem.
Old Apr 30, 2006 | 11:07 AM
yzf125's Avatar
Hi, Is this somthing i need to do right away ? Its the wifes car and i want her to be safe. How much is this job ? Thanks for the reply.
Old Apr 30, 2006 | 11:21 AM
montejass's Avatar
It should still be safe, just an annoyance. I am sure the long term problems associated with the noise/feel could eventually cause failure.
I would check with your dealer and ask them if there is a re-call open on your car for this ISS problem. Rough cost if I remember was around $150-$200 for the re-lube patch.
Does anyone remember the TSB # on this one???
silver86
Nov 20, 2009 11:06 AM
labnjab
Jul 1, 2009 08:51 PM
Endo
May 4, 2009 02:35 PM
White05LT
Feb 14, 2009 02:28 PM
Sciggy
Mar 5, 2008 08:08 AM
