Clicking After Using Remote Start
Old Dec 15, 2013 | 05:41 PM
ohsix_242's Avatar
Default Clicking After Using Remote Start
Hey, I just heard some clicking after starting up my 2006 LTZ using the remote (not after starting it with the key). It went on for a minute after I shut the car down, and then stopped on its own. It sounded as if it was coming from under the hood, so hopefully it's nothing too serious. It's probably worth noting that it's a chilly night here in Florida, so I wonder if that had an affect on it.
It didn't affect how the car drove or acted (other than the clicking obviously). Any opinions or ideas would be great!
Old Dec 15, 2013 | 06:46 PM
Are you sure it's coming from the under the hood? It could be under/in the dash? It's been a common occurrence with the 06-07, there are 3 actuators that go bad and start clicking under the dash. I have the same problem with a bad actuator that usually only occurs when I switch between hot and cold settings.
Old Dec 16, 2013 | 06:29 PM
ohsix_242's Avatar
I'll have to look into that. It probably is coming from under the dash. I can live with not starting the car using remote start, but hopefully it can be easily fixed. Thanks for the answer!
By the way, I got 2 flowmaster 40 series' and 3.5 inch slanted tips on the other day. Looks really really nice, and sounds beautiful when it's not at a little less than 1500 rpm. Just a bit of a drone that I'll have to get used to! Really happy with it overall though. I have to wash her again soon and get some pictures uploaded!
Old Dec 16, 2013 | 07:05 PM
Mine happens with and without using the remote start, I should have been more clear on that. I haven't used my remote start in over a year because of the CEL (check engine light) has been on because of the 'tighten gas cap' message that still hasn't been remedied yet.....
Congrats on the new exhaust set-up also.....
Old Dec 31, 2013 | 04:25 PM
lemkec's Avatar
Default Damper actuator clicking chatter
Have you fixed your actuator issue and if so did you do it yourself and how much of a pain is it? Mine is intermittent when you actuate the passenger side from hot deck to cool deck it chatters for about 30 45 secs then stops. sometimes no heat then it starts working.
I am not afraid to dig into the dash but am to the point where the dealer service guys could fix it for less time etc..
opinions?
Thanks
Old Dec 31, 2013 | 08:55 PM
ohsix_242's Avatar
opinions?
Thanks
I found out that the clicking has only been a problem when the air is on its coldest setting. When using remote start, the air starts up for a minute and then stops. That's why I though it might be a problem wih the remote start feature.
It's strange, but it may be a result of work I had to have done on the blower after I bought the car since there were problems with that. I'm not sure what the deal is with it, but I haven't done any work to it since my original post.
Old Dec 31, 2013 | 09:00 PM
ohsix_242's Avatar
OK, I now I actually did some more reading on the issue. It's definitely an A/C problem, and it sounds like it might be a pain to get into. I'm thinking the dual climate control has to do with it, but I'll probably just take it in somewhere to get it fixed rather than digging in there myself.
Old Jan 2, 2014 | 11:33 AM
trainrvw's Avatar
If it is a temperature actuator, don't pay someone to do something that's very easy to accomplish. Remove the glove box and the two screws for the passenger actuator. Purchase one from online and not a cheap one. Make sure you turn the connector to the door that will open and close said door and determine that this is your issue. You may even open your old actuator and reconnect the plastic wheel that has dislodged. My 2006 LT passenger actuator clacked until I viewed a video on youtube that made it possible for me to try myself. It worked. Good luck!
Old Jan 10, 2014 | 09:15 AM
Hiroska's Avatar
I fixed mine, pretty easy, but a pain. I love not hearing it though ^_^
Old Jan 10, 2014 | 09:22 AM
I head it in my 08 Malibu LTZ it sounded like a heater blower motor? Not too worried about it because it was -20 * at the time. It hasn't done it again
bigdomvegas
Oct 21, 2017 07:54 PM
BigEd
Jul 2, 2014 03:21 AM
Inkedpinkedstarr
Mar 22, 2014 10:11 AM
Chevy Kid
Mar 14, 2014 06:59 AM
motoguy1012
Jun 24, 2007 07:41 PM
