check engine light
Old Nov 21, 2006 | 12:22 PM
wiz kidd's Avatar
Default check engine light
hey, does putting a high flow cat cause the check engine light to come on???
it just came on today(that i noticed anyway), is there anyway to check to see what the problem is without taking it somewhere to get it code read???
Old Nov 21, 2006 | 12:31 PM
Default RE: check engine light
[IMG]local://upfiles/714/561C133131DA43C7B18F44CDED0846B6.gif[/IMG]
Josh, It seems like any time that you mess with the exhaust system, it seems
to eventually cause the check engine light to come on. I think the
only way to get the code is to have it read. I will search the forum
post, because I am sure that this has been posted before. Good Luck...
Oh, waiting for pic's of your Monte...
`Space
Old Nov 21, 2006 | 12:49 PM
wiz kidd's Avatar
thanks so i guess i'll have to have it erased, hopefully it doesn't hurt nothing for the emmissions up here
and as for the pics i just bought a camera myself (kodak z650) should be in in a couple weeks, so i'll have pics then, maybe not with the car clean cuz thats when our snow is gonna start, and with snow comes lovely salt *ggrrrr!!!*
Old Nov 21, 2006 | 01:00 PM
rrobert05's Avatar
Autozone can read the code for you for free and reset it to
Old Nov 21, 2006 | 03:41 PM
wiz kidd's Avatar
i'd have to go to the states for that, i think i might have someone up here than can do that for me
Old Nov 21, 2006 | 07:12 PM
Backinblack's Avatar
My cat clogged up at 70,000 miles and did'nt cause the check engine light to co,e on even though the car was just about undrivable by the time we figured out what was wrong and got it to the shop. I had the u bend delete dona as well as having a high flow cat installed along with a less restrictive resonator. The car is much quicker and the chech engine light has'nt come on since the mods to the exaust system. I believe you have another issue and it is'nt related to your exaust system unless it's the o2 sensor. Hope you don't have an expensive problem to fix. The last time I had the check engine light come on was due to fault emissions components which was an $80 fix....good luck with your ride.
Kenny
hotrodharley
Nov 15, 2013 11:37 AM
J_Bru_Ha_SS
Jul 30, 2007 09:08 PM
BeachBumMike
Sep 21, 2006 10:48 PM
malletboy
May 28, 2006 06:07 PM
rich131
Dec 16, 2005 02:07 AM
