Check engine light
Old Dec 9, 2009 | 11:30 AM
sotmelo's Avatar
im having trouble viewing the links since im on my work computer and it doesnt have a .pdf reader and im not allowed to download stuff on here.
i can change the knock sensor for $130. installed and all
im putting in my downpipe as soon as i get my FWI from wbodystore
Old Dec 10, 2009 | 03:05 AM
sotmelo's Avatar
Question
BUMPIZZLE;
I NEED HELP
Old Dec 10, 2009 | 04:41 AM
Wilco's Avatar
DTC P0327 or P0332
Circuit Description
The knock sensors (KS) produce an AC signal when specific frequencies are detected. When the engine operates, the powertrain control module (PCM) learns a minimum and maximum frequency of noise of normal engine operation. The KS system monitors both knock sensors in order to determine if knock is present. If the KS system determines that excessive knock is present, the PCM retards the spark timing based on the signals from the KS system. The PCM then retards the timing until no knock is present. When the PCM detects a frequency that is less than or more than a defined range, DTC P0327 will set for a failure in KS 1 which is located on bank 1 on the drivers side of the engine or DTC P0332 will set for a failure in KS 2 which is located on bank 2 on the passenger side of the engine.
Conditions for Running the DTC
• DTCs P0106, P0107, P0108, P0116, P0117, P0118, P0125, P1114, or P1115 are not set.
• The engine speed is between 1,600-3,000 RPM.
• The manifold absolute pressure (MAP) is less than 45 kPa.
• The engine coolant temperature (ECT) is more than 60°C (140°F).
• The engine run time is more than 20 seconds.
• The ignition more than 10 volts.
Conditions for Setting the DTC
The PCM determines that this frequency is less than or more than the expected amount for 3 seconds or more.
Action Taken When the DTC Sets
  • The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
  • The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Inspect the KS for proper installation. A KS that is loose or over torqued may cause either DTC to set.
For an intermittent, refer to Intermittent Conditions .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
  1. [*]
Step
Action
Values
Yes
No
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
Important: If an engine knock can be heard, repair the engine mechanical condition before proceeding with this diagnostic.
  1. [*]
Does the scan tool indicate that this diagnostic failed this ignition?
Go to Step 3
Go to Diagnostic Aids
  1. [*]
Is the resistance of the KS within the specified range?
93-107K ohms
Go to Step 4
Go to Step 6
  1. [*]
Is any signal indicated on the DMM while tapping on the engine block near the knock sensor?
Go to Step 5
Go to Step 6
  1. [*]
Refer to Circuit Testing in Wiring Systems.
Did you find and correct the condition?
Go to Step 9
Go to Step 7
Replace the KS. Refer to Knock Sensor (KS) 1 Replacement or Knock Sensor (KS) 2 Replacement .
Did you complete the replacement?
Go to Step 9
  1. [*]
Go to Step 9
Go to Step 8
Replace the PCM. Refer to Powertrain Control Module (PCM) Replacement .
Go to Step 9
  1. [*]
Does the DTC run and pass?
Go to Step 10
Go to Step 2
With a scan tool, observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Follow those guidelines!
Old Dec 10, 2009 | 10:53 AM
sotmelo's Avatar
the question i have right now is
if i buy a tuned PCM from zzp, will the Upgraded Gearing fix my gear ratio thing?
hotrodharley
Nov 15, 2013 11:37 AM
J_Bru_Ha_SS
Jul 30, 2007 09:08 PM
BeachBumMike
Sep 21, 2006 10:48 PM
malletboy
May 28, 2006 06:07 PM
rich131
Dec 16, 2005 02:07 AM
