Check engine light
Old Dec 8, 2009 | 02:17 PM
sotmelo's Avatar
Exclamation Check engine light
So I Went to My Buddy's House, & He Has an OBD Scanner, & we plugged up my car & i got these codes. I know the P0420A is because of my clogged cat, but i just got a ZZP downpipe and ima put it in and i understand that the code will stay until i get a PCM tune. i just have no idea wtf the other 2 are. he told me something about "knocking" i need sum help.
P0332B
P0420A
P0730C
Old Dec 8, 2009 | 02:27 PM
sotmelo's Avatar
Unhappy
im not sure if i posted this thread in the right forum section.
so im just gunna bump it.
Old Dec 8, 2009 | 02:31 PM
It's in the right section. Did you notice this sticky that is 2 posts above yours?
https://montecarloforum.com/forum/sh...ad.php?t=17144
Should let you know in more detail about your OBDII codes. Did you already install the downpipe?
Old Dec 8, 2009 | 02:35 PM
sotmelo's Avatar
Red face
thanks for the help man. u never let me down.
no i have not yet installed it, i got it in the mail yesterday and im waiting for my FWI to get here to do them both the same day. its taking long because of powdercoating.
Old Dec 8, 2009 | 02:41 PM
sotmelo's Avatar
Angry
so if im not a moron, this is whats wrong with my car
DTC P0730 Incorrect Gear Ratio
DTC P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
DTC P0420 Catalyst System Low Efficiency
Old Dec 8, 2009 | 02:48 PM
Oh I was gonna say maybe it was installed wrong so the pipe was hitting something and setting off your knock sensors.
Old Dec 8, 2009 | 04:15 PM
sotmelo's Avatar
Question
whats a knock sensor?
Old Dec 8, 2009 | 04:25 PM
sotmelo's Avatar
Lightbulb
basically, i wanna know what it is i need to do to fix this so i can get rid of the darn check engine light.
Old Dec 8, 2009 | 06:58 PM
Wilco's Avatar
You'll find this is great reading for this DTC P0730 Incorrect Gear Ratio:
http://www.sonnax.com/tech-articles/TASC-TIP-06-04.pdf
This link explains what the code is and how to check for faults (Also pretty enlightening): DTC P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
http://www.gm-trucks.com/forums/inde...howtopic=73881
Old Dec 9, 2009 | 10:05 AM
sotmelo's Avatar
Exclamation
To fix my gear ratio thing can i just get a tuned PCM?
i asked my buddy that owns CompTurbo [compturbo.com] what could possibly be wrong with my Knock Sensor and he said i should replace it. he gets a discount and says he can get it real cheap.
