check engine
Old Feb 19, 2007 | 08:11 AM
dailydriverca's Avatar
Default check engine
My check engine light comes on now after installing K and N cold intake. Any idea on how to solve this?
Old Feb 19, 2007 | 10:16 AM
wiz kidd's Avatar
Default RE: check engine
mine's the exact same way right now...i think its just the cold weather right now...i'm gonna wait till spring and see when it warms up whether or not the check engine light is still on..
if it doesn't work then i'll try what mickey told me to do and disconnect the negative battery cable for an hour and hope that it resets all the codes and adjusts to the cold air intake being there
i think thats just the luck we have having all the cold weather up here in ontario ...and i bet your a LOT colder up where you are then me
Old Feb 19, 2007 | 08:52 PM
InTheIROC's Avatar
Hard to say without reading the code(s)... did you accidentally leave something unplugged?
Old Mar 15, 2007 | 01:49 AM
04 Intimidator's Avatar
Get it checked at Autozone or get a scanner for about $100. My light comes on frequently, but it is from the HiFlow Cat I have on causing the rear O2 sensor to freak... getting the code pulled out on my next reprogram.
J_Bru_Ha_SS
Jul 30, 2007 09:08 PM
BeachBumMike
Sep 21, 2006 10:48 PM
malletboy
May 28, 2006 06:07 PM
White05LT
Jan 31, 2006 02:49 AM
rich131
Dec 16, 2005 02:07 AM
