catalytic converter code
Old Jun 24, 2013 | 02:30 PM
Spiked's Avatar
Default catalytic converter code
So, my cat's clogged up and was sending its code when I got dyagnostics done. I got a 3" downpipe from ZZP. Just wondering if the code will go away when I install it.
Old Jun 24, 2013 | 09:03 PM
Hard to say since you did not share what code your got.
If it's a P0420 code and you are not using an OEM cat, you stand a chance of getting the code again. You mentioned a ZZP DP, if this has a high flow cat, you stand a HIGH chance of getting the code again, even though there may be nothing wrong. The O2 and PCM is calibrated to understand readings from the OEM cat, so non-OEM cats don't always play nice.
I offer a service to delete the P0420 code. See the link below:
https://montecarloforum.com/forum/pr...impalas-42773/
thewhitestcarlouknow
Mar 7, 2022 05:50 PM
Dec 21, 2007 08:13 PM
04monte_Carlo
Oct 5, 2007 03:43 PM
Sackaphone
Apr 29, 2007 03:24 PM
mtwallet
Feb 25, 2007 09:16 PM
