car won't start
Old Jun 15, 2009 | 04:24 PM
danboz's Avatar
Unhappy car won't start
I have a 2003 pace car edition SS and after I turn the key off the radio will stay on after I open the door. I have to turn the key to ACC and back to get the radio off. does not happen all the time but when it does the next morning the battery is completely drained. Something is drawing power with the key off. But it only does it when the radio wont shut off???? Can someone plese HELP!!!!!
THANKS IN ADVANCE!!!!!
Old Jun 15, 2009 | 04:59 PM
The Popcorn King's Avatar
you say it ONLY happens when you open the door?
What about your dome light? Does it come on when you open the door also?
Old Jun 16, 2009 | 04:19 PM
danboz's Avatar
The car is designed to shut off all power off once the doors are open. I am sure you know this. but when I open my door the radio stays on and only when that happens the next morning the battery is completely dead. And no the dome light is not coming on when I opened the door yea I had to check lol ....
Old Jun 16, 2009 | 04:46 PM
I wonder if he BCM has anything to do with it.
Old Jun 17, 2009 | 09:44 AM
The car HAS to know when a door was opened, so is there any switches in the door that trigger this? Could be a problem there.
Old Jun 17, 2009 | 11:10 AM
Here is something else you can try.
See if the dome light turns on with the pass side door open. If it does, then you have a switch problem. And i THINK its inside the door. Since i dont have a 6th Gen , i cant open my door and see. Then again, it might be the same. I'm not sure.
But start with the logical. Check the pass door and go from there. It could just be your door switch thats rusted closed.
Old Jun 17, 2009 | 04:21 PM
danboz's Avatar
I will start there thanks alot guys
RonKennesaw
Jan 5, 2015 04:49 PM
Aslan
Dec 12, 2010 11:56 PM
Dyonysis
14
Jul 4, 2010 08:17 PM
waywardangel
Nov 2, 2009 08:52 AM
ChevRev34
Feb 24, 2008 01:10 PM
