7th Gen ('06-'07): Car will not turn to off position
Old Feb 6, 2021 | 07:36 PM
ThomasB81677's Avatar
Default Car will not turn to off position
I have an 06 Monte Carlo with 180,000 miles. Had to just replace the whole shift linkage and the transmission cable that runs to it. We get that taken care of and now the car won’t go into the off position. It starts and runs fine, everything works fine. The steering wheel isn’t disengaging when I try to turn it off though. It did this a few times before and I would play with it and eventually get it to work right. It’s very annoying because I’m going to have to unplug the battery post every night and plug it back, and it’s a new battery. Any idea how to get this car to turn off completely?
Old Feb 6, 2021 | 07:47 PM
USPatriot1963's Avatar
Default Won't shut off?
I have seen this before. Remove the ignition switch and check the the condition of the transmission shift cable. The switch itself might have an open contact internally.
Old Feb 12, 2021 | 01:51 PM
Reego's Avatar
Default Problem w/car not turning off
I have had that problem with my ‘04 MC.... I had to remove the center console, I then found a cable that was sticking. Once I fixed that, the problem went away.
James0301
Mar 31, 2023 09:51 AM
InTheBlue
Aug 15, 2017 08:19 PM
charvel5150
Mar 18, 2015 02:34 PM
Adam Metz
Nov 14, 2013 12:47 PM
fedspunisher
Dec 19, 2006 04:25 PM
