Car randomly Dies
Old Jan 14, 2010 | 01:47 PM
seawolf18's Avatar
Default Car randomly Dies
I am having an issue with my 01 monte SS randomly dieing while go down the highway. I have a scan tool and there are no codes in the computer. I also noticed while driving at night my dash light will dim way down for a few seconds and then come back bright again. After it dies you can usually throw it in neutral and start it back up again.
Last night it died while coming home from work. I threw it in neutral but it wouldn't restart. I finally let the car coast to a stop. I turned the key off and removed it, put it back in and it started back up again with no problems. I drove the rest of the way home with no problems. Suggestions?
Old Jan 14, 2010 | 02:05 PM
wiz kidd's Avatar
i've heard of issues like this and it was a part called a body control module, which is a dealer item only
now that might not be the problem, wait to see what a few other people say, i've just seen this cause the exact same issues on a lot of other chevy cars
Old Jan 14, 2010 | 02:38 PM
seawolf18's Avatar
I was leaning toward the BCM, but any opinions on it are sure welcomed.
Old Jan 14, 2010 | 02:41 PM
does your headlights dim down when your dash lights go dim
Old Jan 14, 2010 | 04:00 PM
jibb3r's Avatar
Ah yes. I remember the nightmares of those exact issues. It would die at any random point and start right back up. Wouldn't matter if I was accelerating to highway speeds, or coasting to a stop - it would die without warning. I had the crankshaft position sensor replaced in the beginning of November 09 and it hasn't died since then.
Old Jan 14, 2010 | 07:28 PM
seawolf18's Avatar
No, the headlights do not dim when the dash lights do.
owens91
24
Dec 3, 2013 08:13 PM
kody02ss
Dec 28, 2011 12:01 AM
jimmyed
Oct 22, 2010 11:27 PM
erickson483
Sep 19, 2010 01:57 AM
dirty mech
Jul 24, 2010 01:17 AM
