01 monte, randomly dies.
Old Oct 20, 2010 | 05:14 PM
jimmyed's Avatar
Default 01 monte, randomly dies.
3800. Changed the fuel pump, still just randomly shuts down going down the highway. Like you shut the key off. radio is still on, lights stay on, motor just quits.
It will start after several trys. When trying to start it doesn't even try to fire unless its going to start. When it does it starts right up. Runs great when it is running. Ideas?
Old Oct 20, 2010 | 05:51 PM
jimmyed's Avatar
It usually takes 15-20 seconds before it will start.
Old Oct 21, 2010 | 01:34 AM
nitehawkjcb's Avatar
So it'll attempt to turn over, just won't fire up? If so, your crankshaft position sensor is probably bad.
Old Oct 21, 2010 | 08:30 AM
jimmyed's Avatar
Cranks just fine, wont fire till its ready to start. Which usually takes 15-20 seconds.
Old Oct 21, 2010 | 09:40 AM
SAMSET99's Avatar
yea mine was doing the same thing. no pattern at all just random as ever shuts off.
i changed the crankshaft position sensor and it has not done it since.
Old Oct 21, 2010 | 11:56 AM
jimmyed's Avatar
special tool required for the balancer removal?
Old Oct 22, 2010 | 11:27 PM
Yes. Just go on ebay and look for a 3800 crank pulley remover or something. There's one for 3800 and 3300 motors specifically.
Drew Watson
Jun 21, 2023 12:38 PM
Monte922
Jul 12, 2016 06:13 PM
owens91
24
Dec 3, 2013 08:13 PM
dirty mech
Jul 24, 2010 01:17 AM
seawolf18
Jan 14, 2010 07:28 PM
