5th Gen ('95-'99): Car dies when stopped.
![Question](https://montecarloforum.com/forum/images/icons/icon5.gif)
Hello all I've had my Monte Carlo since the beginning of September and I've been having problems with the car "choking" when stopped. The car bogs down and dies. My dad and I have changed the oil, flushed it all out, changed the coolant sensor, replaced the coolant, I've checked the battery with a multimeter to see if it was a bad batter or a bad alt and both came out fine. The battery is also 7 years old though. So now I'm stumped on why this is happening. The car has 195k miles.
Thank you all.
Thank you all.
Thank you all.
Thank you all.
I am thinking though from the description it is your Catalictic converter most likely plugged. All this stuff happened on cars I have owned. The stuff you did is normal maintenance stuff, and may not make the difference you want.
where the green arrow points make sure that is plugged in.
More monte owners may have more suggestions.
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
![](https://montecarloforum.com/forum/attachments/monte-carlo-repair-help-8/14204d1412638006-car-dies-when-stopped-0d83_12.jpg)
I'm wondering about worn out spark plugs. If they have over 100K miles on the plugs, they have been on borrowed time. Really old/worn plugs can allow the car to run but crazy stuff like stalling at a stop can be common place.
Also, if you do not know the maintenance history of this car, I suggest you read the thread I linked below (it's meant for 100K maintenance but can be worth taking a look at and some of the maintenance things left neglected could cause problems like stalling):
https://montecarloforum.com/forum/fw...0-miles-46078/
Thank you for the replies. I do not know the history of the car itself and I have looked into that thread. I'll look more into it when I'm not on mobile. As far as the catalictic converter goes I don't have one. They cut it out and put a midpipe there. I will start to look into what you guys have told me this weekend hopefully that helps. It's my fiancés' car and she is afraid to even drive it because it dies randomly. Thank you very much.
Idle air control valve, it doesn't trigger a check engine light and when it's clogged but it kills the car when stopped unless you rev it up, also if you rev it up once while it's cold it will start bouncing the rpm, Google ways to test how to determine if the idle air control valve has failed that might be a good start, on American cars its a cheap part 30-50 on Japanese cars like Honda it costs anywhere from 150-300. review your search results with the future wife she might agree or disagree to the symptoms.
With those kind of miles... no idea on Maintenance
Fuel filter and or fuel pressure could be the culprit.
Change the filter (Fuel) and check the fuel pressure at the fuel rail...
May just be a failing fuel pump.
