Can't believe people overlook it
Probably the most forgot about fluid in automobiles, brake fluid. I have changed my fluid once with valuecraft brake fluid. Today I was painting my calipers so I flushed the old fluid out. This is from the master cylinder and rear calipers/lines. Remember, this fluid only has ~12,000 miles on it.
I worked as a salesman in a brake shop. We always recommended a flush for the soul purpose of adding to the bottom line. It is an easy way to make fast money.
I have noticed that over time the pedal will get softer after a few hard brake applications. I have a tendency to drive my Monte quite spiritedly on deserted back roads. From my research, this pedal feel come from the fluid absorbing water and lowering the boiling point of the fluid. Not to mention, clean fluid can't be bad for the ABS system. For 6 bucks you can flush the entire system out and put good fluid in. That's cheaper than an oil filter.
I've driven cars that were at least 30 yrs old and never had brake fluid issues. The only time it was changed when i would do disk brake upgrades.
I agree with those who say they have never heard of problems with the brakes as a result of old fluid. But I would agree, it's probably a good idea to flush it out and put some good clean stuff in from time to time.
Power steering fluid is probably the second most over looked fluid to flush....
I once drove a 73 AMC Hornet SportAbout from NJ to CA that was mostly stock. From what i recall, the brake fluid had never been changed. Never gave me any problems.
People, also dont forget to flush the toilet. LOL
