Can't believe people overlook it
Old Jul 26, 2010 | 03:10 PM
aussiek2000's Avatar
Default Can't believe people overlook it
Probably the most forgot about fluid in automobiles, brake fluid. I have changed my fluid once with valuecraft brake fluid. Today I was painting my calipers so I flushed the old fluid out. This is from the master cylinder and rear calipers/lines. Remember, this fluid only has ~12,000 miles on it.
Old Jul 26, 2010 | 03:42 PM
wnmech's Avatar
Thats terrible looking. I am starting my 100K change all fluids on my 03 SS and the brakes are on the top of my flush list. Do you think that it may be that less expensive valuecraft brake fluid?
Old Jul 26, 2010 | 04:44 PM
I have no doubt that is part of it. I put prestone DOT 3 fluid back in.
Old Jul 26, 2010 | 05:18 PM
GrandPaDave's Avatar
Even though dirty brake fluid is unattractive, I've never heard that it leads to the wear and tear of any parts. (As in tranny fluid or engine oil.) I could be wrong, just haven't run across anyone mentioning it.
I worked as a salesman in a brake shop. We always recommended a flush for the soul purpose of adding to the bottom line. It is an easy way to make fast money.
Old Jul 26, 2010 | 05:38 PM
I have noticed that over time the pedal will get softer after a few hard brake applications. I have a tendency to drive my Monte quite spiritedly on deserted back roads. From my research, this pedal feel come from the fluid absorbing water and lowering the boiling point of the fluid. Not to mention, clean fluid can't be bad for the ABS system. For 6 bucks you can flush the entire system out and put good fluid in. That's cheaper than an oil filter.
Old Jul 26, 2010 | 05:42 PM
I agree. If one drives aggressively, clean fluid can only be a good thing.
Old Jul 26, 2010 | 06:55 PM
The Popcorn King's Avatar
I've driven cars that were at least 30 yrs old and never had brake fluid issues. The only time it was changed when i would do disk brake upgrades.
Old Jul 27, 2010 | 05:40 AM
Most people would probably never notice a difference. Only fluid I have left to change for now is the power steering fluid.
Old Jul 27, 2010 | 07:32 AM
I agree with those who say they have never heard of problems with the brakes as a result of old fluid. But I would agree, it's probably a good idea to flush it out and put some good clean stuff in from time to time.
Power steering fluid is probably the second most over looked fluid to flush....
Old Jul 27, 2010 | 08:34 AM
I once drove a 73 AMC Hornet SportAbout from NJ to CA that was mostly stock. From what i recall, the brake fluid had never been changed. Never gave me any problems.
People, also dont forget to flush the toilet. LOL
