caliper issue on 02
Old Dec 31, 2007 | 08:13 AM
luckydogie's Avatar
Default caliper issue on 02
I have a problem with the front passenger brakes hanging up.Brand new rotor and brake pads.It seems the caliper puck is not coming out square with rotor.When I pump brakes pads are not flat on rotor and the caliper is about 1/8 inch out of square from front to back on pad.This is cocking the pads on rotor and car is undriveable.I've pulled it all apart at least 6 times,switched caliper bolts and don't know what else to check.Can a caliper piston be 1/8 to 3/16 out of square?Any help would be greatly appreciated.
Old Jan 1, 2008 | 12:21 PM
RocknSS04's Avatar
Default RE: caliper issue on 02
I think it might be wise to invest in a re-man'd caliper. The're not too expensive, and sometimes well worth the grief. Suggestion: paint it before you put it on, or they look like crap.
Old Jan 2, 2008 | 01:20 PM
luckydogie's Avatar
Thanks for the advice. Went out and bought a new caliper with bracket and pins for $44. Works great now,I think the problem was where the pins go through the mounting bracket and not enough play.Used neversieze,could that be it?
deeds081
Nov 29, 2007 08:48 AM
zipsayain
Mar 31, 2007 09:35 PM
White05LT
Dec 18, 2006 07:20 AM
spavo
Nov 13, 2005 12:38 PM
kissmyss03
Jun 27, 2005 03:46 AM
