Camaro caliper swap...
Old Dec 17, 2006 | 07:23 PM
White05LT's Avatar
Default Camaro caliper swap...
So! Christmas time is here!!
I have a 2005 MC LT with the 3800 v6. I'm looking to swap the calipers with those of a 99 Camaro (F-body). My question is this. I have 16in rim (stock) on my MC. Will the rim be big enough to accomidate the larger caliper? Also I haven't measured the rotor yet, but I believe the fronts on my MC are the 12in.
I plan to upgrade to Brembocrossdrilled rotors to work with these calipers. Will it work??
Old Dec 18, 2006 | 07:20 AM
04 Intimidator's Avatar
Default RE: Camaro caliper swap...
It should work fine. ZZP sells a kit that you you are describing.
http://www.zzperformance.com/grand_p...ts1.php?id=591
BeachBumMike
Jun 11, 2014 04:39 AM
ChibiBlackSheep
Jun 5, 2009 08:51 AM
deeds081
Nov 29, 2007 08:48 AM
spavo
Nov 13, 2005 12:38 PM
kissmyss03
Jun 27, 2005 03:46 AM
