A/C trouble
Old May 28, 2013 | 01:54 PM
BeefSS's Avatar
Question A/C trouble
I recharged my ac in my 05. I let it charge till the can was empty and I removed the can then the air started to get warm and and the ac clutch started clicking. Anybody know what went wrong and how do I fix it?
Old May 28, 2013 | 03:59 PM
Its sounds to me like you have an obvious system leak!
My recommendation would be to take it to a reputable shop in your area and have them check your system.... The clicking of the compressor is due to the loss of freon in the system...Over time the seals tend to break down... Without more info its really hard to try to make a diagnosis...
When was the last time the AC worked? Is this a vehicle you recently bought? It could be a bad condensor,a worn out compressor, Or a hole in 1 of the lines.... Etc...
Obviously the freon leaked out almost as fast as you could put it in.
Old May 28, 2013 | 09:06 PM
crusher38's Avatar
monte carlos and their AC leaks...i'll never understand how NONE of the model years were recalled especially mine
Old Jun 1, 2013 | 04:52 PM
ndaguanno's Avatar
The clicking is the compressor clutch cycling to protect the compressor due to a low refrigerant charge, indicating a leak. Thats the bad thing about those diy kits is they can screw you over majorly, anywhere you go they'll vacuum down the system, recharge it and put a dye in providing its just a leak. Was the a/c working prior to you recharging? If it wasn't working then its probably still low, since you said you put it in the air got warm and its short cycling. With something like that its best to let the pros do it, instead of overcharging and killing a compressor.
Old Jun 5, 2013 | 11:19 AM
BeefSS's Avatar
I mad at the fact is was working well it was blowing cool air and I wanted cold so I got a tall can and put the whole can in and it's been down hill from there. How the heck did a leak pop up
Old Jun 5, 2013 | 11:20 AM
BeefSS's Avatar
Those would be the plains for this weekend thank you for your imput
Old Jun 5, 2013 | 11:21 AM
BeefSS's Avatar
I just hope they don't want an arm or leg for repair
01whitess
Feb 18, 2013 08:55 PM
chorales
Jul 24, 2005 05:33 PM
bumpin_monte01
Jul 8, 2005 08:32 PM
becker2100
Jun 18, 2005 10:06 AM
85_Monte_SC
MCF Website Problems & Issues
Mar 11, 2005 06:38 PM
