a/c not working
Old Jul 12, 2010 | 06:09 PM
craigh4575's Avatar
Default a/c not working
I need some help with my 98 ls MC. The air conditioning is not working. I had a shop add some refrigerant, and some dye to see where it was leaking. I used my buddies ultraviolet light, and I can't find a leak anywhere. My clutch on my compressor isn't even coming on and it started like two weeks after it was charged. As soon as they started to add some refrigerant it kicked the clutch right on. I am assuming there is a leak and that the low pressure switch is keeping it from coming on. I was told not to use the 134a with sealer in it though. Any ideas would be very helpful. If anyone know of a good site for diagrams on the 3.1 motor would be great also.
Old Jul 12, 2010 | 06:27 PM
Justin Knight's Avatar
if you didn't have the yellow tinted glasses its real hard to see the dye from a/c leaks. look again with the proper glasses if you didn't have them. my suspect would be the condenser they are bad in most cars because they get most of the abuse. (road debris, salt, bugs, rain water, etc.)
if you still don't see anything with the right glasses the evaporator is the only component that you can't see physically without removing parts. the evaporator isn't that bad to change in lumina's of the same year and (sorry gen 5 owners ) a lumina is the same car pretty much. its about a 4 hour job for someone who has some experience with dash boards and heater core removal.
Old Jul 12, 2010 | 06:40 PM
craigh4575's Avatar
Yep, I had the glasses on but didn't see anything on it, although it is pretty beat up. Is there any kind of diagram or anything on how to get to the evaporator?
cornerview
Sep 17, 2010 02:49 AM
thedude
Sep 1, 2006 10:26 PM
Seanzy
Jun 1, 2006 08:32 PM
desighitter
May 30, 2006 11:12 AM
01whitess
Dec 20, 2005 03:29 PM
