6th Gen ('00-'05): Bumping klanking thunking noise when hitting a bump
Old Mar 21, 2020 | 11:17 PM
Krowman's Avatar
Default Bumping klanking thunking noise when hitting a bump
Ive replaced everything on my front end n it still pops or thunks when I hit a bump please help I'm at my wits end
Old Mar 22, 2020 | 10:39 AM
Some things to check out on this issue hit the link.
not sure what you have meant by everything,
But did you replace the sway bar bushings?
what about the engine mounts at the front? Thats the black arms that attach the engine to the front support.
front and lower engine mounts.
Sometimes it can just be a loose bolt or one that hasn't been properly torqued to specs.
I once helped a friend of mine with this and we jacked it up put it on jack stands and then checked everything till we found it. in his case it was the struts that were bad.
https://www.google.com/search?client...+the+front+end
Old Mar 22, 2020 | 03:21 PM
Krowman's Avatar
yeah ive replaced them mounts cv axles transmission hubs breaks and rotors control arms ball joints struts sway bar end link bushings tie rods inner and outer rack and pinion subframe bolts and bushings rims and tires
Old Mar 26, 2020 | 11:28 AM
Here is something I found that could help?? check the link.
https://www.chevytalk.org/fusionbb/s...php?tid/48028/
Old Mar 28, 2020 | 06:42 PM
Glen01SS's Avatar
By "subframe bolts and bushings" you mean the engine cradle? I had a thunking noise that the dealer said was cradle mounts (out of warranty). I decided to live with it but it went away on its own somehow. (?) So no help there.
Years ago, I started hearing a noise from the passenger side that might match what you hear and was told I needed new struts and/or bearing, but the tires weren't wearing abnormally. It went away when I replaced the battery! From talking to a mechanic, he theorized the brace over the battery was either loose or had some kind of tension in it that released when removed. If you haven't done anything to the braces and strut tower brace, one could be loose.
michelob
Feb 15, 2020 05:04 PM
iMSeRiOuS
Nov 25, 2012 09:51 PM
5207234w
Jan 26, 2009 11:42 AM
roboticboredom
Nov 26, 2008 04:26 PM
Darkness98
Apr 25, 2006 02:02 PM
