6th Gen ('00-'05): bucking, 10mpg, no codes no leaks
Mrs. Nightmagic, I am a computer tech and I can tell you, if you know computers even if you are just a little savvy. You are Start phone savvy as Well. The thing is you have to stop Looking at it as a phone. Our cell phones are no longer phones. They are pocket computers. Think about it, there is an operating system, you can download programs. If you have a newer printer you can even print from your phone. But the phrase "Smart Phone " is confusing. With this picket computer you can make and receive calls. Otherwise, it's just a computer.
Give it a shot. You may surprise yourself!
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
Give it a shot. You may surprise yourself!![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
![ROTFL](https://montecarloforum.com/forum/images/smilies/lmao.gif)
![Cool](https://montecarloforum.com/forum/images/smilies/cool.gif)
ok so i had my mechanic scan the pcm today because even tho it may not be sucking down a ton of gas anymore since the TBS swap, and it may not be bucking as bad...theres still a lack of power when i tromp on it, and it miss fires. SO when it was just parked it was cyl 3...when we started driving down the road it became cyl 2. when we got back to the shop and he popped the hood, he checked the coil pack and didnt see any problem there, popped the hose off the fuel regulator and said he smelled gas, change it, and he said to clean out the M.A.F. sensor because the readings werent all that great for it. but not so bad that i need to buy a new one. he also suggested in replacing fuel filter and because of a teeny crack in the coil change that after the other stuff is taken care of. after all this is done and i still have the issue...change the cat. no sensors are coming up and aside from the MAF with slightly off readings everything was reading good and normal. what sucks about the fuel regulator is that its off my old engine...and i never had problems. find it odd that now i do. i hope they are not pricey....i havnt looked up the cost yet. im convinced that this car must have everything brand new....i swear she is jealous of the new truck.
![bat](https://montecarloforum.com/forum/images/smilies/bat.gif)
Opinion Needed: Whine/Humming Noise and Bucking
peeper
07-17-2014 03:34 PM
5th Gen ('95-'99): 1998 Monte LS - Random Hesitation, Bucking, or Misfire.
donorlow
03-10-2013 10:14 AM
