Passenger floorboard leaks
Old Oct 1, 2007 | 12:07 AM
DebbieJ's Avatar
Default Passenger floorboard leaks
Does anyone have an idea on this. My carpet is getting soaked.
DebbieJ
Old Oct 1, 2007 | 12:30 AM
lakeman_21's Avatar
Default RE: Passenger floorboard leaks
Well what year and model is your monte? Does your floor have any odor to it? It could be your heater core going out.
Old Oct 1, 2007 | 12:31 AM
2000LS's Avatar
crystal ball says 'cowl seal'
Old Oct 1, 2007 | 07:21 AM
Laserblue06ss's Avatar
If it is clear water it isn't the heater core.My 2000 SS had the water leak on the passenger's side and it was the AC condenser drain hose.They are known for clogging shut.You can pull it off,clean it out and re-install it rather easily.It is on the firewallon the passenger's side,about a foot above the frame rail.It is a L shaped rubber hose,about 2 inches long,about the diameter of your finger.When I took mine off,about a quart of water ran out.
Old Oct 5, 2007 | 06:54 PM
DebbieJ's Avatar
Thanks guys for the info. I should have said it is an 87 monte. There is no smell with the floor board leak. The water is definately coming from the back of the floor board. (I put a plastic bucket under there.) I will check the suggestions out.
Debbie
myfirstcar
Jun 16, 2012 05:26 PM
Weber's Monte
Apr 30, 2009 01:37 PM
rconkin
Jun 30, 2008 07:30 PM
DebbieJ
Oct 1, 2007 12:05 AM
chasedcash
Oct 6, 2005 10:01 AM
