broken pushrod
Old May 22, 2014 | 06:24 PM
thump1st's Avatar
Default broken pushrod
Has anyone ever found a broken pushrod in their engine? If so, whats the cause & can you simply replace the pushrod?
Old May 23, 2014 | 10:57 AM
vikesfan's Avatar
there are a few reasons this could have happened.
if the rotation of the cam, roller, rocker, and valve free of any kinks, it could have just been a bad rocker.
pull the valve cover and if you can remove the broken pushrod and all debris, you can just put in a new one as long as the roller and rocker is not damaged.
Old May 23, 2014 | 02:12 PM
jim1405's Avatar
It's also possible the rocker arm bolt threads may have stripped out. They are easily damaged if they were ever over torqued. When I replaced my intake manifold gaskets I used a Lisle 48300 pushrod remover which lets you remove the pushrod without unbolting anything. This is for the 2.8, 3.1, 3.4, 3.5 and 3.6 engines but if you have the 3.8 I don't think this will help.
If you do happen to have a stripped out bolt thread they make Time Sert kits for this very repair. Seems like most of the reviews of it say it's better than using a heli coil fix.
Old May 24, 2014 | 07:37 AM
What year and size of motor?...
Old May 24, 2014 | 07:02 PM
thump1st's Avatar
thanx for the replies fellas. I replaced the pushrod. the rocker arm was fine. Don't know how the rod broke. Got the car started & that ticking sound is gone. But, still doesnt sound right.
Also, got trouble codes 13, 17, & 36. I know the exhaust isnt torqued to spec cause smoke comes out. Can the o2 code trigger cause of this? Dont know what to make of the other 2 codes tho. Crank & Cam sensors should be good
augi
Sep 18, 2012 08:20 AM
NewFish97MCLS
Mar 24, 2012 03:26 PM
04 Intimidator
Oct 19, 2011 10:42 PM
Gr4v3_7
Oct 7, 2007 04:18 PM
fever42
Nov 1, 2005 09:58 PM
