Info: Bright Lights Not Staying On
Old May 4, 2015 | 11:06 AM
wkimes's Avatar
Default Bright Lights Not Staying On
I have a 2002 SS Pace Car. No matter if the headlight switch is pulled out for headlights, or if it is pushed in. I can pull the turn signal lever and the brights come on, but when i let go they will not stay on anytime night or day. I have looked over everything I can find. Could the lever be broken??? Any info would be helpful.
Old May 4, 2015 | 11:28 AM
wkimes's Avatar
I forgot to mention, There is no click either. Just pulls and then goes back when it is let go. I am guessing it could be a broken switch. If this is the case does anybody know how hard it is to replace????
Old May 4, 2015 | 11:29 AM
Here are some links to try...there might be something in them that may help I know some are labeled low beam but they have several posts.
https://montecarloforum.com/forum/mo...=dimmer+switch
https://montecarloforum.com/forum/in...=dimmer+switch
https://montecarloforum.com/forum/ge...=dimmer+switch
Old May 5, 2015 | 10:20 AM
wkimes's Avatar
I have read through those, but I do not think that is my issue. If I turn on the headlights, the low beams work fine. If I turn them off the bright lights dimmed down for running work fine. If I pull the turn signal lever the brights come on just fine. Just will not stay on when lever is let go. I am really starting to think it is a lever issue
Old May 5, 2015 | 11:32 AM
It's most definitely just a problem with the lever
Old May 5, 2015 | 01:24 PM
wkimes's Avatar
How hard is the lever to replace. I would want to do it myself to save money, but not sure if this is somthing easy enough for me to do myself.
Old May 5, 2015 | 01:35 PM
06mistreSS
May 4, 2024 05:21 AM
oaky812
Jun 7, 2011 11:44 PM
Randdady
Jan 28, 2011 09:26 PM
pizzarrhea
Oct 6, 2009 09:36 PM
Zeronx
Sep 12, 2007 08:51 PM
