Brake Pad Replacement Problem .... Ooops!
Old Feb 14, 2012 | 10:17 AM
asmart82's Avatar
Default Brake Pad Replacement Problem .... Ooops!
I was changing out my brake pads yesterday and while depressing the piston, I forgot to remove the cap on the reservoir to release the pressure. Unfortunately, as I was depressing the piston, I heard a pop and saw fluid draining down onto the driveway. When I looked under the hood, there was a fluid leak between where the master cylinder and power booster connect. Any ideas what I might have gotten myself into here? I'm hoping its just a master cylinder replacement as I am not certain what to do with a power booster!
Old Feb 14, 2012 | 01:45 PM
asmart82's Avatar
Update: I removed the master cylinder and pressed in on the piston(?? Not sure what it is actually called) and brake fluid shot out of the farthest hole (opposite side of master cylinder where the power booster connects). I am assuming fluid should come out of both holes?
englundjd
Jul 24, 2024 09:52 AM
JaxJim
Oct 18, 2016 02:58 PM
callie100
Sep 26, 2011 08:23 AM
EarnhardtZ71
Mar 20, 2011 07:56 PM
Endo
Mar 9, 2010 12:14 PM
