98' z34 rear brake pad replacement problem...
Old Jul 26, 2014 | 05:52 PM
englundjd's Avatar
Default 98' z34 rear brake pad replacement problem...
alright so I'm putting new brakes on the monte and I got everything torn down on the rear on both sides and have the new pads put in but i cant for the life of me get the brake piston to slide back in and I'm using a big c clamp so i can put it all back together... any thoughts on this problem?
It's happening on both sides.
I am kinda wondering if I need to do something with the e-brake cables?
Old Jul 26, 2014 | 06:01 PM
lilmonteZ34's Avatar
You will need a caliper tool kit from auto zone. You can rent it an return it to get your money back when your finish using it.
Old Jul 26, 2014 | 06:17 PM
englundjd's Avatar
welll... autozone isn't open yet I dont think. They just put one in about a month ago and I'm pretty sure the doors aren't open yet. Would O'Reilly's have one? I'd probably just buy the tool.
Old Jul 27, 2014 | 04:14 AM
I would expect them to sale it too. Let us know.
Old Jul 27, 2014 | 12:21 PM
englundjd's Avatar
i got a cheap universal one and got it back together, thank you sir! I didn't realize you had to screw the piston back in.... every other car ive done breaks on all I had to do was c-clamp it and push it back in. Learn something new every day
Old Jul 28, 2014 | 12:49 AM
Great you resolved the problem screwing in a piston, I'm like you all I ever have done are the C clamp style. Nice to know, thanks for sharing your intel...
Old Oct 4, 2015 | 08:57 AM
Moe's Avatar
Moe
Default One bolt issue
Im trying to change the rear brake pads on my 98 monte carlo z34. Once i take the tire off and prepare to remove the bolts holding the pads I saw that its only one bolt (lower). Im use to seeing two bolts (upper and lower) and looking online I dont see any mention of this so I'm simply confused. Help me out.
Old Oct 5, 2015 | 10:01 AM
Whatsup Moe, you reminded me that I should be changing my breaks soon before it get to cold. There should be two bolts though. One at the top an one at the bottom. Hopefully someone can pitch in an be more descriptive. If I manage to do my breaks this week I'll take some pictures.
Old Jul 24, 2024 | 01:49 AM
Morsan1981's Avatar
Default Sliding in rear brake pistons
We just did my brake pads on 99 monte carlo and they do not push in like the front brakes you have to turn them clockwise to push them in.
Old Jul 24, 2024 | 09:52 AM
Just as a heads up, the person you're replying to hasn't been online in 9 years. It's a pretty old thread.
JaxJim
Oct 18, 2016 02:58 PM
asmart82
Feb 14, 2012 01:45 PM
EarnhardtZ71
Mar 20, 2011 07:56 PM
aussiek2000
Jul 22, 2010 07:54 AM
Endo
Mar 9, 2010 12:14 PM
