Brake pad compund
I am going to be upgrading the front rotors and pads. I know they were ceramic from the factory. I plan to leave stock rear rotor, but if they aren't ceramic pads, I'd like to upgrade them to. Does anyone know the factory material on the 6th gen rear brakes? ceramic? organic? semi-met?
EDIT: yes, I spelled the title wrong. lol
In 2000, I'm pretty sure the front and rear pads were organic from the factroy. I know in 2006 the front and rear pads are ceramic from the factory.
I recommend you change all your pads to ceramic. They give you low dust, and nice smooth braking, without being to harsh on your rotors.
I'd stay away from Semi-Metallic, they are hard on rotors. I had semi-metallic pads chew up the rear rotors on a 2000 Bonneville (the pads were practically new, rotors were in good shape when the pads were installed, after a few thousand miles on semi-metallic pads, rotors had grooves in them).
Endo
Mar 9, 2010 12:14 PM
