brake pad sticking
Old Dec 15, 2010 | 10:37 AM
goingforgold's Avatar
Default brake pad sticking
I just put new pads and rotors on my 02 monte. I took it for a test drive and one wheel has a noise that sounds like maybe the pads are rubbing the rotor without applying the brakes. Any ideas as to what I did wrong on that one wheel? I cleaned the slides and greased them when I did the brakes.
Old Dec 15, 2010 | 10:47 AM
What kind of rotors did you put on? Check around for metal shavings. The rotor might not be sitting perfect
Old Dec 15, 2010 | 11:39 AM
The Popcorn King's Avatar
Did you grease the sliders? They sometimes get rusty and can hang up a caliper.
Old Dec 15, 2010 | 01:12 PM
yep greased everything. I think it may be the e-brake on the left rear. Is there any adjustment on the e-brake?
Old Dec 16, 2010 | 01:26 PM
Clueless's Avatar
I have a similar problem with my brakes on my 97 monte but it doesn't make noise. I will find that my breaks are stuck while I'm driving and I have to actually pull up on the pedal to un'stick' my breaks. I don't know what's wrong and this just started happening a few months back.
Old Dec 16, 2010 | 06:16 PM
i think that I'll try bleeding the system and see if that helps.
Old Dec 17, 2010 | 06:16 PM
jshladwig's Avatar
if u only changed ur front pads and rotors then it cant be ur e brake cause ur e brake is in the rears but u might of bought to big of rotors. are ur caliper brackets rusty where the pad sits and slides on? if so sand the contact area wit a soft sand paper and use some silglyde and dont forget the bridge pins
ladybridgeport
Feb 17, 2011 08:30 AM
tommy3678
Dec 2, 2010 07:37 AM
mini64
Sep 29, 2010 12:58 PM
aussiek2000
Jul 22, 2010 07:54 AM
Endo
Mar 9, 2010 12:14 PM
