Brake lights no workie!
Old Jun 21, 2009 | 04:29 PM
BigKev's Avatar
Unhappy Brake lights no workie!
My hazards and blinkers both work but the brake lights do not come on! Is there a switch some where that I need to adjust? The car is a 1985 Monte SS! All help is appreciated. Already checked the fuses and the lights are all good. Same lights as the turn signals and hazards.
Old Jun 21, 2009 | 05:25 PM
Hi Big Kev,
Check on the firewall above your brake pedal &
you should see a metal switch with a button
Check your switch to see if there is contact, when
your brakes are applied.
If you have a electrical tester ? See if there
is power to the switch when contact is made.
If this does not work, check back on your Thread
question & see what our expert tech member's
post. Good Luck from `Space
Old Jun 21, 2009 | 07:53 PM
BigKev's Avatar
I will look into that and let you know if that fixes it.
Old Jun 22, 2009 | 04:44 PM
BigKev's Avatar
The style switch I have is actually aft of the brake pedal. When the pedal is push it breaks contact with the switch which turns the lights on. I think I need a new one.
rg9johns
Jan 2, 2022 05:51 PM
rg9johns
Aug 22, 2014 10:46 PM
hotrodharley
Oct 11, 2013 07:13 AM
Zackb911
Dec 22, 2006 07:22 PM
