Brake bleeding/flushing order
Old Nov 2, 2011 | 10:25 PM
jasonsmith's Avatar
Default Brake bleeding/flushing order
What's the correct brake bleeding/flushing order for an 02 Monte Carlo 3.4L?
The Haynes says Right Rear, Left Front, Left Rear, Right Front.
That just seemed odd.
Old Nov 3, 2011 | 08:12 AM
I always do furthest from the master cylinder to closest, so on our cars it would be, RR, LR, RF, LF.
Old Nov 3, 2011 | 09:14 AM
jasonsmith's Avatar
Is that the furtherest even with the ABS unit in the system?
I've got another older GM car with ABS. And you have to start with the Right Front, because that is the furtherest from the master because of the ABS unit.
Old Nov 3, 2011 | 08:25 PM
Zen's Avatar
Zen
i've always done rear right, rear left, front right, front left.Never had any problems there are some that your suposed to do in an odd order but can get away with just doing the old school way.
Old Nov 6, 2011 | 01:50 PM
jasonsmith's Avatar
I got a repair manual on CD for the 02 Monte Carlo. Looks like it is a type of shop manual as it is very detailed. I got it off eBay.
The order in that manual is the same as in the Haynes: Right Rear, Left Front, Left Rear, Right Front.
So, I'll just follow that order when I flush the brake fluid.
Old Nov 7, 2011 | 08:43 AM
Go for it!
I'm sure as long as you get all the air out it doesn't matter haha
Old Nov 7, 2011 | 11:00 AM
jasonsmith's Avatar
Go for it!
I got the fluid flushed. Only problem I had is I flush via a vacuum at the bleeder screw. But for some reason, the rear bleeders would just suck air. So, I had to let the rears gravity bleed.
Next time I may get a pressure bleeder.
03 monte SS
Jun 29, 2011 01:57 PM
heinzp87
Nov 10, 2010 12:27 PM
Feb 4, 2010 02:48 PM
dkunesch
May 10, 2009 04:46 PM
RickCoMatic
Dec 9, 2007 09:15 PM
