Brake bleeding/flushing order
I've got another older GM car with ABS. And you have to start with the Right Front, because that is the furtherest from the master because of the ABS unit.
I got a repair manual on CD for the 02 Monte Carlo. Looks like it is a type of shop manual as it is very detailed. I got it off eBay.
The order in that manual is the same as in the Haynes: Right Rear, Left Front, Left Rear, Right Front.
So, I'll just follow that order when I flush the brake fluid.
Next time I may get a pressure bleeder.
