Battery post
Hello MonteCarloForum,
Im new here, just found your web site while browsing to get info on my problem for my 95 monte carlo LS.
Got this car 2 month ago (winter car) and the jumping battery post give me problem.
i tight the nuts on it, put a few tie wraps to hold the post tight (seems loose) and still some times i get some drop of current in the car or when i want to start it doesnt until i open the hood and play with it.
it is happen often that jumping post give problem? i checked ebay to get a replacement parts but no chance, any solution?
Thanks a lot
Frank
Thanks a lot
Frank
[align=center]Hi Frank, & Welcome to the Monte Carlo Family Forum.[/align][align=center][/align][align=center]Would you please post more details about your problem.[/align][align=center]What parts are you searching for ?[/align][align=center]Are your Battery Cables bad, or arethe posts on the battery[/align][align=center]lose/bad ?[/align][align=center]Look forward to your future posts, and hopefully one of[/align][align=center]our expert members can assist with your problem.[/align][align=center]Good Luck & Happy Holidays[/align]
oh.... i c your battery is moving in the place holder. (your not jumping it) am i wrong?
if im right then mayby get a small ratchet strap and go around the base plate and ove rthe top of the battery. (this is a quick fix)
to do it properlly go to gm parts direct. if you cant find it there should be a email a representative button or something and ask for the part number.
and if im wrong and your jumping the batter then get a new one.
sorry for the delay, i was really busy at work.
my problem is not at the battery post itself, but at the jumping post. its attached to the fuse box under the hood.
did someone here had this problem before? i think you need to change the full fuse box but its probably a expensive job to do.
just to give you guys a idea of ehat kind of problem i have... this morning start the car and go to work. no problem, when i get to the parking at work i need to pass my card to open the gate... so i open my window and the car shuts off!!!(no more power in the car) i got out of the car, open the hood , shake a bit the jumping post, and the car re fire without a problem. the jumping post might be broken somewhere and dont attach proper to the fuse box, im just looking for a simple and cheap solution to fix my problem
yep its pretty strange, the jumping post gets so hot sometime that i just burn my finger
ill probably this saturday take out the security bar and windshield washer jub to have a look, ill try to post some pics.
thanks
thanks
ok well u didnt answer my question and i still have no idea what the jumping post is but if u can shake the battery junction box (fuse box in the engine bay) and the car will then start i would say you have a loose connection. Since it seems to affect the power to the entire car i would say it is the main power to the battery junction box...find that wire and follow it to the connection and check to c if it is loose or if there is alot of corrosion i would start there
70monte1
Jun 14, 2012 05:12 AM
