7th Gen ('06-'07): Battery draining - Possible electrical problems?
Old Jun 18, 2014 | 09:00 PM
silkwormxl's Avatar
Question Battery draining - Possible electrical problems?
Hello,
I own a 2006 Monte Carlo LT. A couple days ago I went to get into my car and noticed the key-less entry wasn't working. Once inside the car, it was clear the power was drained. I had a neighbor jump me and the car started right up. My neighbor also mentioned they noticed my dome light was on the previous night. Nice of them to mention that now, right? Anyway, I drove to the store, and on the way I noticed what sounded like my door locks locking or unlocking, and then the dome light came back on. After parking and turning the car off, the radio and dome light didn't turn off automatically. Once I got out of the car and locked it, the dome light turned off, but a few minutes later it turned back on. The same thing happened when I got the car back home.
I did some research online and couldn't find a clear answer, so I just pulled the bulb out of the dome light until I could figure out what's going on. But this didn't help as my car was dead again today - something else is draining the battery while the car is off.
I want to point out that last week I noticed water splashing around inside my doors after a rain storm. I looked this up online and found other's with the same issue. I followed their instructions and drained the water from the doors. Could this water have caused some issue? I read that there is a switch of some sort inside the door panel, that controls interior lighting and the remote locks - but have yet to find any diagrams or pictures on how to get to them.
Thanks for any info guys! Really annoying issue here as this is my only vehicle.
Old Jun 19, 2014 | 03:14 PM
It could be possable for the water in the door to be your problem
As for the diagrams my local chevy dealer has provided me any digram I wanted free of charge have you check in wioth a local chevy dealer for a diagram?
Old Jun 19, 2014 | 05:18 PM
silkwormxl's Avatar
I've been looking at this thread as it has a step by stop on how to open the door panel, but I'd still need to know what I'm looking for:
https://montecarloforum.com/forum/mo...removal-20761/
I actually have an appointment to get the recalled power steering pump replaced, so I can ask them if they can provide that diagram. So what do you think it could be IF the problem is in the door? Just a loose connection? Something rusted out?
Old Jun 22, 2014 | 04:06 PM
silkwormxl's Avatar
So I took off both door panels. I checked all the connections - nothing that I could see looked rusted or disconnected/loose.
Is there a possible temporary solution like removing a fuse somewhere? I checked my user manual but the diagram doesn't match the fuse layout inside the car. I already tried removing the dome light bulb - the battery still drained.
Could this be an BCM or ECM issue? I keep reading about people having electrical issues related to those parts.
Thanks!
Old Jun 23, 2014 | 06:33 PM
TomF106SS's Avatar
My Original battery started draining itself after 2-1/2 years.
The sides were blown out like a balloon from heat. It gets hot under that hood, couple raodtrips to florida and texas and a few heatwave traffic jams.
Bought/installed an optima yellowtop.
was dringing dead in less than a year.
Full replacement under warrantee.
that lasted over 3 years. Then the draing problem again.
Now I have Optima redtop. Didn't really fit, kinda wedged it in.
Its been good for over 1 year.
Still have original alternator (which surprizes me on a GM) but really its a denso, made in japan?
And, my streo with 6 amps can draw a Max of 90 Amps, but I never play it that loud. Might draw 25 when I crank the tunes.
I'd replace the battery first.
Old Jun 24, 2014 | 08:39 AM
03SSLE's Avatar
Have you checked the door jamb switches to insure they are being fully depressed when the door is closed?
When the sides of a battery bulges it means the battery is being overcharged. I would have the charging system inspected. Overcharging the battery can cause it to explode.
mount02
Mar 14, 2013 04:59 PM
rgant_19
Jun 22, 2009 03:31 PM
jessymo
Feb 19, 2009 10:07 PM
Pitdawg
Jan 31, 2008 05:32 PM
pat2187
Sep 17, 2005 09:35 PM
