Bad hesitation at low RPM when cold
Old May 13, 2007 | 09:50 PM
enibum's Avatar
Default Bad hesitation at low RPM when cold
I have a 2001 SS with 3800. Before the engine warms up, the motor stumbles when trying to take off. When it reaches about 3000 rpm it is like somebody turned on a switch and it comes to life. Runs real smooth. I know somebody is going to tell me that it is the plugs and wires. I would buy that if it were missing at all rpm's whether hot or cold. It acts like a sensor is telling the comp that the engine is warm all the time. My thermostat has been replaced and the engine temp sensor is showing what appears to be an acurate reading. I also replaced the MAP sensor since I accidentally broke it when checking it. I tried cleaning the MAF sensor but may not have got it clean enough.I thought carb cleaner would be good enough. I thought about the TPS but doesn't make sense because the problem goes away when the motor warms up. Any ideas, anybody?
Old May 13, 2007 | 09:56 PM
scc24540's Avatar
Default RE: Bad hesitation at low RPM when cold
my car has that same problem, but now its doing it all the time nonstop, i belive its the MAF sensor cos if i go out there and tap on it or unhook it and rehook it then it'll work properly for a while then go back to acting stuipd. thats just my 2 cents tho i could be wrong[:'(]
Old May 14, 2007 | 10:05 AM
DESS03's Avatar
try the iat sensor it may be malfuntioning like you said could be thinking the car is getting hotter air than it should or you could be having an o2 sensor problem
Old May 14, 2007 | 01:41 PM
scc24540's Avatar
ORIGINAL: DESS03
quick way to check that is just unplug it, also the air idler sensor (i belive thats it) could be giving you a problem
Old May 14, 2007 | 08:25 PM
scc24540's Avatar
well i changed teh MAF sensor today and its all fixed now so thats prolly ur problem
NYGiantsfan
Jul 24, 2013 08:11 AM
NYGiantsfan
Jun 17, 2011 01:55 PM
JayteeWilson
Nov 6, 2010 03:05 AM
StanzManianDevil
Feb 22, 2009 11:28 PM
StanzManianDevil
Dec 24, 2008 06:46 PM
