hesitation(cold) and weird shift into 2nd after zzp supercharger kit cpm??
Old Jun 4, 2013 | 12:53 AM
NYGiantsfan's Avatar
Default hesitation(cold) and weird shift into 2nd after zzp supercharger kit cpm??
i installed the zzp SC kit and now when i start the car it hesitates when i try to step on gas even lightly.noticed the problem goes away when it warms up.
it almost feels like the car is shutting off, no jerking or chocking noises
vac lines all ok, intake is plugged in rite..
any one have a clue?
could it be the pcm?
Old Jun 10, 2013 | 10:10 PM
it does it when its in park as well.
Old Jul 17, 2013 | 09:26 PM
Red Nightmare's Avatar
do you still have the factory pcm?
and if you do...did you have it tuned for the supercharger?
Old Jul 24, 2013 | 03:59 AM
nope i got a tuned one with a SC kit from zzp i was speaking to them and they said i need a new one and were going to replace it under warranty
Old Jul 24, 2013 | 08:11 AM
Could also just be the IAC, but the tune might be choking the car until it's warmed up. When it is warmed up then the oxygen sensor starts to talk to the PCM and adjust the air/fuel ratio. When the car isn't up to temp, the PCM just dumps the maximum amount of fuel
Bait
32
Jan 18, 2013 12:04 AM
HappyWolverine
Jul 3, 2010 09:17 PM
Frosty LS1
Aug 24, 2009 02:14 PM
