6th Gen ('00-'05): back fire on start up
Old Oct 9, 2024 | 12:07 PM
goatman's Avatar
Default back fire on start up
2001 monte carlo
3800 series 2
When tempature starts to get cold out, car always does a small backfire on 1st start of the day.
It hasn't done it all summer, but did last year when it was cold out ?
Any ideas or tests I could do.
Last year, I cycled the fuel pump 2 times before I cranked it and that seemed to help.
Thanks in advance !!
Goatman
Old Oct 9, 2024 | 01:57 PM
Are these legit backfires? If so, I'd be very worried about blowing up the intake / potential for fire. Unfortunately not uncommon on 3800s.
First thing I'd check is the FPR to see if it's leaking fuel into the intake.
Old Oct 9, 2024 | 02:39 PM
goatman's Avatar
I had the whole regulator, catch on fire, blow plenum apart issue about 5 years ago. not covered by recall in 2001. but covered in 2002. Whole different delema...
it's just a small backfire, but smoke does come from under the hood.
I just kept cranking it and it fired right up after the backfire.
I was thinking I'd check Fuel pressure when key is on 1st cycle in the morning, maybe pump is bleeding off at night?
Old Oct 10, 2024 | 10:20 AM
Have you 100% ruled out the FPR since its so easy? It wont necessarily have the exact symptoms each time they fail.
Checking the pressure is also a good idea. Could point to a leaky injector or several.
Old Oct 10, 2024 | 10:31 AM
goatman's Avatar
No I haven't checked the regulator, Whats the best way to check it?
I will check fuel pressure tomorrow.
thanks !!
Old Oct 10, 2024 | 12:13 PM
Originally Posted by goatman
Whats the best way to check it?thanks !!
Just pull the vac line off and smell/check for gas. Have the car running first. Give it a few minutes, sometimes it takes a few to spit some gas out.
Old Oct 10, 2024 | 05:19 PM
Assuming those dates aren't typos, that was literally 20 years ago. Absolutely possible for it to fail again from age. It's just a simple diaphragm inside that can leak / deteriorate.
How is the battery? It's not uncommon on 3800s for spark timing to get a bit wacky if voltage is very low / cranking is ultra slow right at first. But if it's doing this every time even if electrical is strong, then it's probably something else.
How does it run otherwise - fuel trims / vac levels ok?
​​​​​​Shouldn't have to go through 2 full prime cycles to get pressure again though, the lines are pretty small in volume even if dry.
I also wonder about injectors. Id be curious to prime it, then pop the rail and injectors off real quick to take a look / sniff. Wonder if one is draining the rail into the engine after it sits for a bit?
goatman
Feb 15, 2023 03:47 PM
bigdomvegas
Oct 21, 2017 07:54 PM
Duradave
Sep 20, 2014 01:59 PM
SgtWyatt
Mar 12, 2012 09:44 AM
jl10899
Dec 24, 2010 09:09 AM
