No Power to Blower Motor
Old Jul 26, 2016 | 12:29 PM
Captn_Cook's Avatar
Default No Power to Blower Motor
I'm trying to figure out this issue i'm having with the AC... When i turn the fan on you can hear the compressor run. When i move the **** that directs where the air goes i can hear the door moving. However the blower motor isn't turning on. I replaced the resistor but it was a no go. I tested the power wire that goes to the resistor and its dead... i tested where the blower motor fuse is and its also dead. Where do i go from here???????????
Old Jul 26, 2016 | 09:25 PM
plumbob's Avatar
What year and trim is your car Captn?
Old Jul 27, 2016 | 03:23 AM
Captn_Cook's Avatar
Originally Posted by plumbob
what year and trim is your car captn?
2004 ss
Old Oct 14, 2024 | 03:18 PM
ElTheomundo's Avatar
Default Same
Have same issue. Power at 30 amp fuse under hood, no power at resistor controller. It is a bear to get hands by wiring harness that has the wire. Did you ever get any help? A diagram of connector would help a lot!
ElTheomundo
Oct 15, 2024 06:44 AM
stevenjfrench
Apr 3, 2017 06:23 AM
Captn_Cook
Sep 16, 2016 07:32 AM
pgibbzz
Jul 22, 2015 09:31 PM
Humble1
Sep 30, 2013 11:07 AM
