6th Gen ('00-'05): anything I should replace when I do the IMG replacement?
I'm going to replace the U&LIMG soon. Is there anything that's going to be remived that should be replaced now? I have already done the coolant elbows. Plugs, wires, valve cover gaskets, water pump? 2002 3.8L 46K. Thanks
Care about modifying the car?
It's a good time to remove the runners and add the HV3 insert, as well as swap the rockers out for something else.
Can always do a Series III aluminum upper intake swap
https://montecarloforum.com/forum/fw...c-heavy-48949/
The U&LIM gaskets finally got replaced. I feel pretty good about it because after looking at the old gaskets, the lower one was starting to leak. The throttle body was cleaned out and I get more power as a result. In addition, replacing the coolant level sensor (again) got rid of the low coolant level indication. The oil pressure is up a little and the temperature is down a bit. All-in-all a success.
