anyone elese have a problem with the intake gasket on 3100 or 3400?
Old Mar 23, 2008 | 10:11 AM
blazerman3's Avatar
Default RE: anyone elese have a problem with the intake gasket on 3100 or 3400?
Our `97 and `98LS`s are doing ok so far....`97 has 88k and the `98 has 105k but was told by the previous owner that the `98 had an engine change so that makes that engine at around 90k. The `97 has the dexcool and the `98 has the green stuff.
Old Mar 23, 2008 | 02:19 PM
rysZ34's Avatar
I might be tempted to drain the dexcool out of the '97...just my opinion though.
Old Jun 29, 2008 | 02:45 AM
mikes03ss's Avatar
i might be a tad bit late to help u , if u havnt already fixed this, fel pro has a gasket called "problem solver" if i remember the price was around $70.00 maybe $80.00 had to do one in a olds alero , only to find out not only was the lower intake was leeking but after the job was done ,220 miles later low coolant light came back on thats when i realized the head gasket was bad so if u decide to do lower intake make sure before u start ,to do a compression check, i did but the alero was not completely cool , i would suggest to do a compression checkafter the car has sat overnite. hope this helps ! if u havnt already done this.
New2MonteNY
Apr 25, 2017 01:59 PM
Andrew
Aug 7, 2013 08:51 PM
Bigray1111
Jan 17, 2013 06:12 AM
Budsjlm
Feb 2, 2012 03:47 AM
Ron A
Jan 29, 2012 10:28 AM
