anyone elese have a problem with the intake gasket on 3100 or 3400?
Old Feb 26, 2008 | 09:28 PM
black04monteSS's Avatar
Default anyone elese have a problem with the intake gasket on 3100 or 3400?
i was just wonderin if anyone elese with a 3100 or 3400 has had the same intake gasket trouble that i was just talking about on another thread...let me know
Old Feb 26, 2008 | 09:44 PM
scc24540's Avatar
Default RE: anyone elese have a problem with the intake gasket on 3100 or 3400?
thats one of the many problems the 3100 has. the intake and head are on such a harsh angle it doesnt always seat well and causes problems. i lost 2 engines due to that stuipd crap. so i just ended up getting a different engine put in
Old Feb 26, 2008 | 09:47 PM
PsuBrock's Avatar
I had to replace mine 2 weeks into owning my Monte. Wonder why the person traded it in....
Old Feb 26, 2008 | 10:48 PM
04 Intimidator's Avatar
The 3100 and 3400 have intake gasket issues??????
J/K.
I actually thought someone had a good fix for this though like they made one from a thick version of feltpro or something.
Old Feb 27, 2008 | 09:54 AM
zk6216's Avatar
I wonder why GM does not try to fix this issue if it happens so frequently?
Old Feb 27, 2008 | 10:13 AM
88ss408's Avatar
yeah the stock gaskets are no good in the older 3x00 but i think that it was fixed in the newer cars
Old Feb 27, 2008 | 11:50 AM
scc24540's Avatar
ORIGINAL: zk6216
that would involve them having to spend money, just like gm knew about the flywheel problems they had in the 90s but never fixed em. which ended up costing me 2200 dollars when it blew apart and tore my tranny up.
Old Feb 27, 2008 | 11:54 AM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
on my 97 I had an intake, then a head gasket, then the timing chain gasket. eventually the oil pump failed and said enough was enough. On my 01 I only had an intake gasket fail.
Old Feb 27, 2008 | 12:39 PM
RickCoMatic's Avatar
Are there any Tell-tale Signs before the Intake Gasket fails?
Or, is it something that happens all at once with no warning at all?
Old Feb 27, 2008 | 02:34 PM
zk6216's Avatar
Gm also had Camshaft problems that they never fixed there camshafts were always made of two much soft metals and they never fixed them but when Chryslar had problems with theirs they were told they had to fix them and they did but gm never changed there cams? I just hope on my 97 i dont have any issues =(
