Any idea where I can grab this at/what it is called?
Old Mar 3, 2022 | 06:48 PM
Justchambers88's Avatar
Default Any idea where I can grab this at/what it is called?
I was replacing the spark plugs and wires when the wrench got caught up on the metal part of this line ripping the old rubber piece holding it in place to pieces. It's on the passenger side, these pics were taken from the passenger wheel area. 1983 CL v8 305 engine
Old Mar 3, 2022 | 07:44 PM
Jeffs02rwdSS's Avatar
It's the heat riser on the exhaust manifold. It's closed when the engine is cold to help with cold start-up .
Old Mar 3, 2022 | 07:56 PM
Thanks! Do you know if it's possible to purchase the rubber fitting or is it an all in one deal?
Old Mar 3, 2022 | 08:09 PM
It's just a piece of rubber hose, you should be able to get at any parts store. Get high temperature hose if available.
Old Mar 3, 2022 | 08:30 PM
oh okay Awesome,Thanks again!
Old Mar 4, 2022 | 04:49 PM
zucchi's Avatar
Ya know, if you know how to fabricate using sheet metal, I would encourage you to make a heat shield to protect the starter and solenoid. If you're ambitious, perhaps make it big enough to shield that rubber boot. That heat-riser thingy and the line that leads to it could very easily be another area for a vacuum leak.
XtroMC2002
Jan 6, 2020 07:53 AM
Furder2010
Dec 30, 2011 12:23 PM
myronprescott
May 22, 2011 04:44 PM
wwestbu1002
Sep 24, 2009 12:13 PM
RickCoMatic
Dec 20, 2007 11:54 PM
