another 3.4L getting hot
LIKE I SAID ALSO KEEP IN MIND:
TO BE SURE TO GET ALL THE AIR OUT OF THE SYSTEM.....
ID BE CURIOUS TO HEAR IF IT HELPED.....GOOD LUCK !
I had an issue on a 3100 when the head gasket failed, it sent compression gases into the coolant system. The gases (air pocket) is hotter then coolant and caused my temp gauge to spike until the T-Stat opened (while the temp gauge was pegged, I had no heat from the blower, once the t-stat opened, heat from the blower again).
Not saying it is, but it might be a head gasket issue. Things to check:
- Make sure the coolant system has been properly bled of air pockets
- Change T-Stat
- Use a scan tool and see if the PCM temp reading matches what's on the instrument cluster (verifies you don't have a cluster problem).
- If a temp sensor fails, typically you don't see a natural response reading on your gauge (temp rises as the car warms up and goes down when the T-Stat opens).
- Get a radiator test tool (loan a tool from the parts store), pressurize the system and check for coolant leaks of or loss of pressure on the coolant system.
If nothing points to the cause of the problem, you might be looking at a failed head gasket.
- Change T-Stat
ladybridgeport
15
12-27-2011 02:02 PM
callie100
10-23-2011 07:08 AM
