annoying ticking noise!!!
Old Jan 29, 2009 | 08:25 PM
magnnuss_75's Avatar
Default annoying ticking noise!!!
hey there guys, this ticking noise is driving me crazy, ive got a 2006 LTZ, after the car warms up and the idle is at its lowest RPM there is this ticking noise that seems to be coming from the passenger side behind the dash...what is this and is there anything i can do about it?........lol..i like to hear the exhaust but when the radio is off this ticking is driving me crazy
Old Jan 29, 2009 | 09:21 PM
Enzo354's Avatar
STILL SLOW
Default RE: annoying ticking noise!!!
Could be something in the air conditioner fan?
Old Jan 29, 2009 | 10:33 PM
it sounds kinda like its in the engine bay but then again it doesnt, doestn happen till it hits about 700-900 RPM's, and the air/heat isnt on, no radio, windows up, ...if the radio is on or you take er up to around 1000-1200 rpms you cant hear it
Old Jan 29, 2009 | 11:01 PM
draxxis's Avatar
To me, it sounds like you must have your fan speed selector on the lowest running position.. I get a ticking sound when it is on the lowest speed.
Old Jan 29, 2009 | 11:20 PM
fans not on at all but, i just seen an old post bout some kind of heater lines causing a rattle/tick noise at low idle...theres a TSB out for it...too bad i bought the car used and dont have a warranty or anything, hopefully thats it and its nothing to worry about
Old Jan 29, 2009 | 11:51 PM
RickCoMatic's Avatar
If the ticking goes away if you add a few hundred RPM.s ... it's the Fuel Injection Pressure Relief Valve cycling Fuel back to the Gas Tank. The noise sounds like its coming from behind the radio ... like at One O'Clock or so ... behind the radio. Usually never an issue unless the car is really low on fuel.
Old Feb 2, 2009 | 08:34 PM
bowtietech's Avatar
The ticking noise you are hearing is created by the evap system purge valve which is mounted on the intake manifold near the throttle body. There is nothing wrong with the purge valve,it is normal for it to make the ticking noise. What happens is the normal ticking noise of the purge valve travels through the metal heater pipes that are attached to the throttle body mounting studs into the heater core which is located behind the passenger side of the dash.Yes,there is a bulletin for this noise. There is an updated heater pipe assembly with rubber insulators where it mounts to the throttle body studs. I have installed a few of the updated heater pipes and it does eliminate the ticking noise. The noise is not a durability issue,just annoying.
nickchilds6
Mar 20, 2021 12:08 AM
2003supersport
Dec 8, 2008 05:15 PM
ivory317
Dec 27, 2007 10:39 PM
96montecarlo
Jun 9, 2007 08:42 AM
87monte
Jan 25, 2007 05:14 AM
