alternator problems
Old Feb 18, 2008 | 07:36 PM
cali2000ss's Avatar
Default alternator problems
I replaced my alternator and the meter is still reading at 10 volts. I unhook my battery and the car dies out. I was wondering if there was another reason why the alternator is not keeping the engine running? I was thinking it could be the electrical connector to the alternator.
Old Feb 20, 2008 | 01:58 PM
bowtietech's Avatar
Default RE: alternator problems
The alternator in your Monte Carlo receives a "turn on" signal from the powertrain control module. The PCM will store diagnostic trouble codes for charging system malfunctions. It might help to get your Monte scanned for any DTC's. Something that you DO NOT want to do is disconnect your battery with the engine running. This can cause many problems and the spending of alot of $$$$$ due to damage that can be inflicted upon the many solid state control modules your car has on board!
natedawg0613
Nov 30, 2007 08:10 PM
charvel5150
May 6, 2007 10:43 PM
rrobert05
Mar 25, 2007 12:34 PM
busterdog
Jun 21, 2006 07:18 PM
bobsicparts
Oct 29, 2005 08:14 PM
