3.8 alternator swap
Old Nov 29, 2007 | 05:33 PM
natedawg0613's Avatar
Default 3.8 alternator swap
My alternator has unfortunately gone bad, I was looking at it and the alternator looks pretty much bolt on, the only problem I have is i dont know how to loosen the belt to get it off. And also if I loosened the belt would it come off all the other pulleys
thanks
Old Nov 30, 2007 | 08:10 PM
RocknSS04's Avatar
Default RE: 3.8 alternator swap
It's pretty easy to remove the belt. It takes a 1/2" drive breaker bar aand put it in the square hole in the idler pulley bracket. Twist the bar to release pressure on the belt, remove the belt, and that's about it.
sal23
Mar 9, 2026 09:38 PM
Budsjlm
Apr 3, 2012 05:43 PM
rrobert05
Mar 25, 2007 12:34 PM
busterdog
Jun 21, 2006 07:18 PM
bobsicparts
Oct 29, 2005 08:14 PM
