Airbag question
Old Sep 4, 2010 | 03:40 PM
xjcurtisx's Avatar
Default Airbag question
are the airbags to the 02' body style the same as the 99' body style? and how hard are airbags to install
Old Sep 4, 2010 | 04:36 PM
Hi `Michael,
Sorry, I don't have the answer to your question(s),
but hopefully one of our member's may
Check back on your thread question.
Also check the below link that has some great
information on airbag installs.
Good Luck
http://www.airbagcenter.com/howtoinstallairbags.aspx
Click above link
Below is a toll free # to call & they maybe able to assist `if
none of our member's has the information right away..
CALL TOLL FREE (1-866-636-2247)
Old Sep 4, 2010 | 06:17 PM
Enzo354's Avatar
STILL SLOW
Airbags as in the ones in the dash, or suspension air bags? I wouldnt put in my own if its the dash ones. Theres too much risk.
Old Sep 4, 2010 | 06:35 PM
xjcurtisx's Avatar
the steering wheel one yeah...
Old Sep 4, 2010 | 07:24 PM
lucian*91's Avatar
its not too hard to take off or replace airbags. or atleast the steering wheel one, the passenger is due to being hidden in the dash. they are more than likely not the same due to steering wheel design.
to take off you should unplug the fuse for airbags, so the SRS system is disactivated, however you could still take them off by not doing this im NOT recommending you to skip it.
then wait ten minutes for the system power to fully drain.
take off the screws to the back of the steering wheel.
needed is a special tool, or a meduim flat head screw driver is just the same. insert into the holes in the back of the steering wheel, and there is a little metal pin you have to move. put the screw driver in there and twist it, may take some time to get used to it but you will find it. once both clips are popped, take the airbag off and push an and twist the clip for the horn to take it off. have the steering wheel strait and unplug the clockspring. once everything is uncliped and its off. just reverse the steps to put it back on. should snap into place
Old Sep 4, 2010 | 07:50 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
Man... Airbags (SRS) scare the poop out of me. Good luck.
Old Sep 4, 2010 | 08:33 PM
nemesis's Avatar
2009 Monte Of The Year
you don't want to take off the screws trust me it's a pain in the *** to put back in. the screws are not what's holding the airbag. there's an empty hole (without screw) next to the screw that lucian*91 talking about, that's the hole you want to stick a screw driver in and twist left.
what's holding the airbag is a thin size wire clip in each of the 3 holes. when you twist the screw driver in the hole the clip release the coil like spring attach to the airbag.
when you get to the last hole make sure you hold on the airbag cuz it will drop straight out. if you don't catch it when it drop the airbag harness and horn wire might rip off then you going to have some problem. the airbag weight a pound or few just letting you know. after it is off the yellow harness is for the airbag that should be pull right off from the steering wheel and the red thin wire is for the horn. push it in and twist to the right.
Old Sep 4, 2010 | 11:40 PM
lucian*91's Avatar
thanks silver for picking up on my slack!! :p
drmrgal
Nov 13, 2017 07:43 AM
owens91
May 11, 2013 09:18 PM
Sciggy
Jul 14, 2012 08:35 PM
jcobz28
Sep 6, 2007 01:14 PM
alesiter
Feb 2, 2007 01:14 PM
