Airbag & Battery light
Old May 8, 2012 | 01:25 PM
FM91's Avatar
Default Airbag & Battery light
Hi, I have a 2003 Monte Carlo 3.4 with approximately 95,000 miles. About a month ago, I began seeing the airbag light flash along with the battery light...And while those are flashing, and I attempt to use the turn signal, all I hear is a buzzing sound....But then both lights go off & turn signal goes back to normal...This is the first issue that I have had with my car....if anyone have info on what may be causing this, I appreciate the feedback...thanx
Old May 8, 2012 | 01:39 PM
Mike 00LS's Avatar
The battery light leads me to believe maybe your alternator is bad. Could also possibly be a start of issues with your BCM
Old May 8, 2012 | 02:07 PM
FM91's Avatar
What is the BCM?
Old May 8, 2012 | 02:21 PM
FM91's Avatar
As far as it being the Alternator, I just put a new battery in 2 days ago, and the car is still running and the battery hasn't been drained by the bad alternator...
cnogood
Sep 20, 2014 04:16 PM
Sciggy
Jul 14, 2012 08:35 PM
terrell293
Apr 30, 2010 09:02 PM
jcobz28
Sep 6, 2007 01:14 PM
alesiter
Feb 2, 2007 01:14 PM
