Acdelco spark plug wires
Old Apr 27, 2014 | 11:14 AM
teddyballgame13's Avatar
Default Acdelco spark plug wires
Hey ya'll,
The old spark plug wires for my car are nicely wired, however the new OEM ACDelco ones I have now are now except for KW #'s on the coil connection. I have a 1998 3.1 Monte btw. Here are the codes, can I look these up? I haven't had any luck thus far and of course customer service is closed for acdelco. The wires have the following numbers:
KW 733
KW 757
KW 769
KW 780
KW 787
KW 857
Any help/advice would be greatly appreciated!
thanks,
Ted
Old Apr 30, 2014 | 05:37 AM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
Just match them up by the length and snap em on. The coil packs should be numbered as to which cylinder is what. Just remove and replace one wire at a time so it doesn't confuse you.
The front side of the engine meaning closest to the radiator are the odd number cylinders the back side are evens.
In most of my time replacing wires, even the delco sets are not quite exact length as the originals but work just fine. Be sure to tie em up as nice and neat as you can
Cowboy6622
Feb 6, 2012 10:56 AM
tridski
Jul 4, 2009 09:22 AM
NewFoundJoey
Jun 15, 2009 09:08 AM
ExplosiveSoundz
20
Oct 13, 2008 11:19 PM
RickCoMatic
Dec 22, 2007 10:45 PM
