ac vents all blowing
Old Jul 2, 2014 | 02:48 PM
yandyriv's Avatar
Default ac vents all blowing
I have a 2003 monte carlo ls I had the intake gasket replaced but mechanic left a*vacuum*hose hanging and my ac is now blowing very poor and through all the vents I cant find where it goes if some one can please post any pics
Old Jul 2, 2014 | 06:41 PM
Aaron0313's Avatar
Is this vacuum line hanging in the engine compartment under the hood or is it hanging inside the vehicle under the dash? Some things like the blend and mode actuators are vacuum controlled.
Old Jul 3, 2014 | 06:59 AM
yandyriv's Avatar
No it is hanging under the hood the line comes from the the left side goes over the strut section and then its hanging behind the motor
Old Jul 3, 2014 | 07:00 AM
yandyriv's Avatar
Im going to post a picture in my album so you can see it
Old Jul 3, 2014 | 08:00 AM
03SSLE's Avatar
Unless it's been removed, there should be a sticker on the radiator support that shows the vacuum line routing.
This may help:
Old Jul 3, 2014 | 11:37 AM
yandyriv's Avatar
Mike thank you. For the diagram the vacuum hose i have loose seems to be number 4 but i cant tell where it goes exactly it look like it goes to the intake manifold ?? Isbthat correct
Dcbank
Mar 20, 2018 09:48 AM
GaJItt
Jul 31, 2015 07:42 PM
fishm3at
Nov 20, 2013 08:01 AM
Doug g
Jun 24, 2009 04:09 PM
S_DAHM
May 20, 2009 07:03 AM
